This discussion topic has been answered Discussion topic: Sky to Freeview .
Message posted on 20 Apr 2024 07:59 PM
H ello . Ive got Sky Q with Sky signature , Broadband essential , and phone anytime phone package. Im wanting to cancel sky signature TV , leaving just broadband and phone . If I do that , to get Freeview is it just a matter of going into my TV control centre ,finding it , and clicking on it as if it was just another channel for example , or am I going to need to have extra bits and pieces of tech to get hold of ,or enter a contract with them ,or reset my TV's innards? (Please keep it simple , Im not techy minded . Thank you .
Message posted on 20 Apr 2024 09:00 PM
The dish is yours.
You can use it for freesat with the correct set top box.
But if you have a working aerial then you simply plug an RF lead from the wall to your TV and tune it.
Message posted on 20 Apr 2024 08:06 PM
Re: Sky to Freeview .
hi @Curtaintop
If cancel Sky Signature then your only choice with Sky is to replace it with Sky Essentials.
This is the only way to keep your Sky Q boxes.
If you just want to watch Terrestrial (Freeview) TV on your TV set then you can do this without the Q boxes but you will need a terrestrial TV aerial.
One of these below if you do not have one already
Message posted on 20 Apr 2024 08:53 PM
Thank you oldfella , yes I want to get rid of my sky Q box , yes I appear to still have an aerial on the roof as well as a dish , so going back to the rest of my question , what is required to get Freeview up and running once the box has been disconnected to return ? ps will they demand the dish back too?
The dish is yours.
Message posted on 20 Apr 2024 10:21 PM
Thank you PanJ 2020 there are two cables coming in from outside and both appear to be attached already , one to the tele and the other to the Q box. Do I just pull out the one to the Q box? Ive found a utube video how to tune, so I should be ok with that bit.
Message posted on 21 Apr 2024 09:03 AM - last edited: 21 Apr 2024 09:36 AM
Two different systems.
Freeview is free to air television broadcast from a transmitter mast and received through an aerial to a television or box with a digital terrestrial tuner.
Freesat is free to air television transmitted from orbit and received over a dish connected to a box or television set with a satellite tuner.
Some televisions are equipped with Freeview and Freesat tuners, others only have Freeview. If an external receiver box is used then no tuner on the television is required but the box itself will be either Freesat or Freeview but not both.
Freeview choice is limited to what's being broadcast from the local mast: this may only be a subset of all channels. Freesat reception is always all the channels on Freesat, but these are now fewer in number than potentially on Freeview. Freeview with Freeview Play (delivered by transmitter and online) has far wider choice.
From later this year, both Freesat and Freeview begin transitioning to the Freely app (online only) in anticipation of the eventual end of broadcast transmission but this app is currently only available on a limited range of hardware and not retrospectively installable.
