Discussion topic: Sky’s - BBC1 recording and playback issues ?
Message posted on 05 Feb 2024 08:45 PM
Good evening Peeps
wondering 💭 if anyone out there is experiencing problems with BBC Channels recording and more importantly playback?
Recording will play happily and then freezes as if paused - can rewind but gets stuck. Cannot play forwards - I can fast forward but when release button Box returns to the frozen frame 🖼️?
Any advice would be appreciated- do NOT want to do a master reset as my 'bride' would not be best pleased if her recordings suddenly disappeared 👻 !!!
regards - Eoin 🤓
Message posted on 05 Feb 2024 08:49 PM
Re: Sky’s - BBC1 recording and playback issues ?
@Eoinrua wrote:
Good evening Peeps
regards - Eoin 🤓
Hi @Eoinrua
Try a Reset Settings in the Q box hidden menu. This will not lose any recordings.
Message posted on 31 Jul 2025 10:03 AM
I have found when I play a bbc recording - the fast forward doesn't work and the remote control won't do anything for about 10 seconds . For example I record Eastenders - when I play it , I want to fast forward The One show credits and it won't work straight away - I have to wait about 10 seconds 😳
Message posted on 31 Jul 2025 10:52 AM
Hi @Mark5644445 I recommend not using fast forward, simply hit Pause, followed by two DirectionRight button presses. The BBC is normally very accurate in starting two minutes in.
Message posted on 20 Sep 2025 06:05 AM
I have exactly the same problem with all recorded BBC programs. Any other channel recording i can fast forward straight away.
