Discussion topic: Sky router network name changed
This message was authored by Paul257 This message was authored by: Paul257
The wifi signal from my sky booster box has spontaneously changed and none of my boxes are now connecting to it. Tgey are joining my bt wifi and they keep losing connectivity as a result
This message was authored by ThePope27 This message was authored by: ThePope27
Re: Sky router network name changed
@Paul257,
Cant change wifi booster ssid unfortunately.
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Paul257
The ssid is different from what it's been for years! Since then I'm having problems as the sky Qbox is linking to my bt router . Won't link when you press the wps button
Hi @Paul257
Is it a Q WiFi booster and to what is it connected?
Paul257
Yes it is a Q booster attached by cable to a BT router. The Sky Q box and three mini boxes all used the WiFi network created by the booster to link together. They now are trying to use the BT WiFi network and have become very unreliable as a result.
Hi @Paul257
Have you tried rebooting the the Booster by disconnecting it's power lead for 30 sec and then reconnecting.
Next carry out a Network Reset on the main Q box found in Q box Home - Settings - Setup - Network.
Select connect to Sky Broadband you will be asked to press the WPS button on the booster (Not on the Q box as the Network reset will start the main Q box WPS automatically).
Paul257
Thanks for your interest. I had already tried all tvat but a sky engineer j it at called and he did a factory reset on the booster box which fixed the issue with the sky WiFi network that has solved the problem.
thanks again
