Discussion topic: Sky remote not responding and Q light is yellow
This message was authored by: MC581
My remote is not responding and my Q box light is yellow
Re: Sky remote not responding and Q light is yellow
Power cycle the box by turning off or unplugging at the wall for 5 minutes then, when the box is back on (hopefully), if your remote is still not working you can re-pair it the box using the instructions here:https://www.sky.com/help/articles/setting-up-q-remote
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Mobile | VOXI Mobile | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Hi @MC581
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
