Discussion topic: Sky remote control
This message was authored by: Mary-Ellen1
Sky remote control
Hi I'm pressing the power on on my Sky remote but it's not coming on. Batteries changed
Re: Sky remote control
Hi @Mary-Ellen1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
