Discussion topic: Sky queue is not working
This message was authored by: JulieCope14
My 2nd sky queue box is not working. It keep saying technical fault
Re: Sky queue is not working
Hi @JulieCope14
Reboot the mini as above.
This message was authored by: Mr+Luis+farina
Re: my mini sky box not working
My mini sky box not working showing 2 xs on settings
