Discussion topic: Sky q
Message posted on 17 Apr 2026 04:36 PM
Sky q
I have just connected to a new Virgin router my sky q box will not accept this and I'm connected to someone else's sky
Message posted on 17 Apr 2026 04:53 PM
Re: Sky q
@Bradders6 wrote:I have just connected to a new Virgin router my sky q box will not accept this and I'm connected to someone else's sky
If you find your new router in the list on your skybox and put the correct password which you should find some where on your new router it log on successfully. Just make sure the correct router from the list the name again is on you new router with you password.
Message posted on 17 Apr 2026 05:01 PM
Re: Sky q
That's the thing there was and is no list it just automatically connected to someone's sky box as I said I'm with Virgin not sky
Message posted on 17 Apr 2026 05:34 PM
Re: Sky q
@Bradders6 do you have mini boxes ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
