Discussion topic: Sky q
This message was authored by: Awsum1
Sky q
Skyq very slow to react to inputs. That is, changing channels takes forever and sometimes doesn't happen at all. According to the box there is good signal, internet connection is good too. This is also happening on minibox in another room. Seems to all point to q box. I have gone through the usual reset process but no change. Any ideas pls??
Re: Sky q
@Awsum1 just to check  you tried rebooting your main Q box ie
then
rebooting  the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
