Discussion topic: Sky q recording
Message posted on 25 Sep 2023 12:41 PM
Sky q recording
Main sky Q box with recorded / downloaded programes during the viewing the screen will go blank for a couple of seconds and then come back on .
The TV or the box does not go in to standby mode and this only does it with recordings etc
Message posted on 25 Sep 2023 12:48 PM
Re: Sky q recording
Hi @Dazzyc1
