Discussion topic: Sky q not working
This message was authored by: Anjusharma
Sky q not working
I've up loaded the software and now the upstairs box isn't working
Re: Sky q not working
Hi @Anjusharma
Reboot the mini as above.
Avatar for Anjusharma
Level 0 icon
I've done all that was suggested
they are saying it is a software update
I've followed the instructions but the upstairs q box is still not working
What is saying it is a software update @Anjusharma ???
If it is a message on you Television it may be a television update that you need to clear with your Television remote (ie not your Sky remote)
Exactly what is the message??
