Discussion topic: Sky q mini
This message was authored by: Rich37
Sky q mini
Hi, we recently had an engineer to sort sky TV in our new home but the mini box for upstairs is not working.
Re: Sky q mini
Hi @Rich37
Reboot the mini as above.
