Discussion topic: Sky q mini not working
Message posted on 24 Aug 2024 08:05 PM
My Sky Q remote doesn't turn on the sky box and the box doesn't turn on when I press the power button. I have to keep switching the box on and off then reset the remote with 7 and 9 pressed together. Then it works for a day and then doesn't turn on the next day
Message posted on 24 Aug 2024 08:24 PM
Re: Sky q mini not working
Hi @Dal5
You could try a Reset Settings in the mini Q box hidden menu.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
