Discussion topic: Sky q mini not working
This message was authored by: S_Kaur
My sky q mini not working, its stuck on step 1 0f 4 , tried to reset sky q main, remote and sky q mini , nothing helped.  Can anyone help please?
TIA
Re: Sky q mini not working
TIA
Hi @S_Kaur
If your mini remote will not get you past step 1 of 4 try the following.
Press and hold 7 & 9 together on the remote until it's led flashes 4 times.
This will set it to infrared mode which will work any Q box.
However it must have line of sight and pointed directly at the mini to operate it.
See if you can get past 1 Of 4 with it in infrared mode.
If you get the mini working then you can re pair the remote correctly by completly resetting your Bluetooth remote.
Avatar for S_Kaur
On Which remote shall i try that? Main one or mini one?
That would be the mini remote @S_Kaur .
It is the mini you are trying to get past the 1 of 4 step
Avatar for S_Kaur
@oldfella  I tried it few times, it doesn't work. No light flashes.
Hi @S_Kaur
Does the mini remote have a microphone button for voice control?
Avatar for S_Kaur
Yes it has
