6
This discussion topic has been answered Discussion topic: Sky q mini connection issue
This message was authored by: Iain65
Hi, I'm trying to connect a sky q mini for the first time and suspect it's too far from the main box (old house and reasonable distance), any idea what the range is and is there a booster available?
I assume the mini box connects via a direct link and not through Wi-Fi?
thanks!
Re: Sky q mini connection issue
@Iain65 wrote:
Hi Oldfella,
one further question please, I'm not on sky broadband so do I directly connect the Ethernet cable from the back of the Sky Q to the Sky mini? Or through my network (Gigaclear)?
thanks again
Iain.
Hi @Iain65
With 3rd party broadband;  If it just the mini you are connecting by Ethernet then this needs to be to the main Q box.
If you connect all Q Boxes then it can be to the 3rd party Router
thanks!
Hi @Iain65
Minis connect by WiFi to the Sky Q mesh (generated by Sky Routers and Q box.
However they can be connected by Ethernet.
If on 3rd party WiFi you ideally need to connect all Q boxes to your router if using Ethernet.
You could try first rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all this you could ask Sky for a Q WiFi booster to position midway between the mini and your main Q box.
Avatar for Iain65
Thank you, that's really good information, I'll try the Ethernet route first and see if this helps.
cheers, Iain.
Avatar for Iain65
Hi Oldfella,
thanks again
Iain.
@Iain65 wrote:
Hi Oldfella,
thanks again
Iain.
Hi @Iain65
Avatar for Iain65
Hi @oldfella,
Thanks all the help, it's now up and working 👍
Iain
This message was authored by: lpardoe
Hi I have a similar problem to this. I have a sky Q box in my living room (connected to virgin hub via WiFi). I have a mini box in my kitchen connected via WiFi, all works fine. I want a mini box in my summer house (miles away from sky Q box). If I leave my existing set up as it is, and just connect a new mini box in the summer house straight to main sky Q box, via ethernet.. will it all work ? Thanks
