Discussion topic: Sky q mini boxes
Message posted on 13 Dec 2025 10:38 PM
Sky q mini boxes
My sky q mini boxes not connecting to router have reset several times still won't connect. When I look on my sky app it shows mini boxes are connected but they are not. Any ideas?
Message posted on 14 Dec 2025 12:56 PM
Re: Sky q mini boxes
Sky mini box is not connecting to sky main box
Message posted on 14 Dec 2025 01:40 PM
Hi @moulden01
Unless you are on Sky Broadband, minis connect to the main Q box and not your router. Also minis will not connect to the Sky Max router.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
