Discussion topic: Sky q mini boxes not working
Message posted on 09 Mar 2023 10:21 PM
After a Sky broadband issue in my area, two out of my three mini boxes will not re connecy
Message posted on 09 Mar 2023 10:35 PM
Re: Sky q mini boxes not working
Hi @M+mcc
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the mini as above.
If the minis still do not connect try a Network Reset on the mini starting with the one nearest to the main Q box
You will be asked to press the WPS button on the main Q box (not the mini).
If a connected mini is nearer than the. Main Q box you can use that for the WPS.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 11 Sep 2023 01:14 AM
Sky mini boxes have a fundamental design flaw, the put the ventilation at the bottom of the box not the top, this causes them to overheat ALOT, a trick is to keep your mini box turned upside down putting the vents facing upwards, this actually allows the box to cool more efficeintly
Sky box design engineers seemed to forget that heat rises and thus failed to vents in the top side of the box
Message posted on 11 Sep 2023 05:39 AM
You have added to a 6 month old thread where the OP has made no mention of the mini box getting hot let alone overheating.
