Discussion topic: Sky q mini box
This message was authored by: Jaynemit61_
Sky q mini box
My remote for my sky Q mini box is not working - new one being sent. We cannot control my daughters skyQ mini box in her room as it is not connected to the new fibre as it went wrong yesterday when fibre was installed. therefore we cannot use the box. anybody help?
Re: Sky q mini box
Hi @Jaynemit61_
If you have the new Sky Max router,  then the mini box if using WiFi,  will only connect to the main Q box.
If you had to press the button on the mini to switch it on, With the mini box on with green led try completly resetting your Bluetooth remote.
Press and hold 7 & 9 together on the mini remote until it’s led flashes four times.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
