Discussion topic: Sky q mini box
Message posted on 10 Oct 2023 12:39 PM
Sky q mini box
Hi, I am a sky customer but very recently I have switched to BT for broadband only. Could someone tell me how to set up my mini sky q box for my second tv set
Message posted on 10 Oct 2023 01:10 PM
Re: Sky q mini box
Carry out a Network reset as follows .
Message posted on 10 Oct 2023 01:23 PM
Re: Sky q mini box
Hi oldfella,
Many thanks. Much appreciated your help!!
