Discussion topic: Sky q mini box
Message posted on 20 Jul 2023 11:34 AM
Sky q mini box
Hi all can someone help me
my sky q mini box keeps losing everything and going back to wanting to be paired again . And a few times has completely reset itself . The internet is good and strong no problem there . Is there anything I can check or is the box probably faulty,
Message posted on 20 Jul 2023 11:45 AM
Re: Sky q mini box
Hi @Metcalf93
Just be aware that your mini box if connected by WiFi will only connect to Q mesh WiFi.
So unless you are on Sky Broadband it not connect to your router Network.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
