Discussion topic: Sky q mini box will not connect
Message posted on 11 Nov 2024 09:33 AM
Why won't my sky q mini box connect to my main box? I have followed the instructions in the box, followed all the instructions that appear on screen, I have restarted my main box, my mini box and my WiFi three times but I still can't connect.
Message posted on 11 Nov 2024 10:15 AM
Re: Sky q mini box will not connect
Hi @SDB131
Reboot the mini as above.
