Discussion topic: Sky q mini box technical fault
Message posted on 21 Nov 2023 09:13 AM
My sky mini box is just showing technical fault. I've tried re booting it but hasn't solved it. Connection to wifi and sky main box both showing a tick
Message posted on 21 Nov 2023 10:05 AM
Re: Sky q mini box technical fault
Hi @Rob511
Reboot the mini as above.
Message posted on 21 Nov 2023 10:48 AM
Yes tried all these things but still the same issue.
Message posted on 24 Jan 2025 02:24 PM
Have had the same thing since Nov 24, stil lnot fixed. Sky sent a new minibox which worked for a few days and then stopped again with ther same fault. Waiting on an engineer to turn up.
Message posted on 24 Jan 2025 04:06 PM
Engineer came today and swapped out the main sky q box, issue resolved.
