Discussion topic: Sky q mini box not working
This message was authored by: Ms1313
My sky q mini box has stopped working showing error code MR 104
Avatar for Ms1313
Level 0 icon
Re: Sky q mini box not working
Qsky sky box mini box is not not reading main box have tried to reconnect over a dozen times have also shut whole system down and rebooted several times
Hi @Ms1313
Complete the following procedure.
Reboot the mini as above.
