Discussion topic: Sky q mini box not working
This message was authored by: mantejsaj123
Dear team,
sky q mini box not working
Re: Sky q mini box not working
@mantejsaj123
I’m afraid you’re not talking to Sky Customer Services here. This is a forum where customers try to help other customers. We'll need more information in order to provide advice.
@mantejsaj123 wrote:
Dear team,
Hi @mantejsaj123
Reboot the mini as above.
