Discussion topic: Sky q mini box issues
This message was authored by: Turnersarah
My sky q mini box won't connect.  It has been fine for months but now I'm having problems, I've rebooted it a good feed time along with my main box but nothing is working
Re: Sky q mini box issues
@Turnersarah Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @Turnersarah
If reboots don't work try a Network Reset on the mini.
Avatar for Turnersarah
This worked, thank you so much
