Discussion topic: Sky q mini box crashing
This message was authored by: KKKK2
My mini box turns on and connects ok but keeps crashing and rebooting.
Does box need replacing or any other ideas to fix?
Re: Sky q mini box crashing
@KKKK2 Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @KKKK2
First try a Reset Settings in the mini box hidden menu.
After the Reset you will have to re pair your mini Bluetooth remote.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
