Discussion topic: Sky q lead
This message was authored by: Luisaj1976
Sky q lead
Hi
i I need a mains cable that goes into the sky q box and the plug socket in the wall, the sky it directed me here!! Apart from buying one, can sky help me does anyone know?
thanks.
This message was authored by: xchrissyboix23
Re: Sky q lead
Hello
id recommend contacting customer services for this im not sure if there is a charge though but they will be able to advise you. Hope this helps
Please Note: I am just another customer not an employee
Sky Glass Gen 2 43” Volcanic Grey, Sky Live, x1 Sky Stream Puck, Sky Broadband Superfast (Part Fibre), Sky Broadband Hub 4.2 (SR203), Sky Ultimate TV, Sky Cinema, Sky UHD & Dolby Atmos, Whole Home, Ad Skipping. Former Sky Q Customer
Re: Sky q lead
@Luisaj1976 wrote:
Hi
thanks.
What happened to the cable you had?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Luisaj1976
Re: Sky q lead
It has fraid, I've had it for over ten years mind, so it's not as if I've had it a short time, I don't want to leave it till it causes a fire. Is that ok?👍
Re: Sky q lead
hi @Luisaj1976
If it has a standard 2 pin 'figure of 8' plug going into th eback of the SKY Q box & not a small round multipin plug then SKY do  not supply these generally.
These are available from many outlets including local hardware stores & online
They are available in many lengths - just look for a IEC C7 power cable or as mentioned 'figure of 8'
