Discussion topic: Sky q keeps disconnecting from my broadband, seems to be a common fault
Message posted on 02 Oct 2023 08:00 PM
My sky q box keeps disconnecting from my broadband, I have to enter my Wi-Fi password on a daily basis, looks like a very common problem but haven't seen any worthwhile solutions, it's really annoying now
Message posted on 03 Oct 2023 08:10 AM
Re: Sky q keeps disconnecting from my broadband, seems to be a common fault
The only real permanent solution is to not use wifi.
Message posted on 03 Oct 2023 10:09 AM
Hi there @ELLS247 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Lisa - Sky Tech Team Expert
Message posted on 05 Nov 2023 01:28 PM
I've got the same problem! Changed from Sky broadband to another provider. Initially had the Sky Q box connecting by Wi-Fi but was so intermittent and as we have multi room a major pain! Bought a long Ethernet cable to make it wired - still disconnecting issues! When you go to system set up you can see it connecting/disconnecting on the screen!! All other wireless devices - iPads/phones still work fine on the Wi-Fi!!
Message posted on 05 Nov 2023 01:56 PM
@Wayne16 wrote:I've got the same problem! Changed from Sky broadband to another provider. Initially had the Sky Q box connecting by Wi-Fi but was so intermittent and as we have multi room a major pain! Bought a long Ethernet cable to make it wired - still disconnecting issues! When you go to system set up you can see it connecting/disconnecting on the screen!! All other wireless devices - iPads/phones still work fine on the Wi-Fi!!
You have to disable wifi to test ethernet properly
Message posted on 05 Nov 2023 02:27 PM
Sky boxes dont like 5ghz wifi. Have you tried connecting to the 2.4ghz band?
If you cant see two seperate bands when you search for wifi via sky youll need to seperate them in your router settings (google it its easy)
This solved our issues.
