Discussion topic: Sky q hdmi connection
This message was authored by: Andym1963
Should I connect sky q to a hdmi port that supports  a 4k 120hz in put or will any hdmi port be OK?
Re: Sky q hdmi connection
hi @Andym1963
For SKY Q 4K  HDR you only need an HDMI 2.0 - 50hz for SKY Q  - not sure if you might need 60Hz for some of the apps - you don't need to use an HDMI 2.1 port (120Hz)
If not using 4K then any HDMI will work
Edit : I think some HDMI 2.0 ports can actually support 120Hz but do not think all do  - as I mention above 120Hz is not needed for SKY
