Discussion topic: Sky q broadband connection issues
Message posted on 05 Jul 2024 09:39 PM
Would an Alexa ontop of Sky q box cause broadband connection issues?. No issues with Sky q till a month ago and connection between main box and minis keeps dropping out driving us crackers. Done usual resets, works for a bit then back to connection issue. Any advice helpful
Message posted on 05 Jul 2024 09:45 PM
Re: Sky q broadband connection issues
Hi @Ad6
Any WiFi device stacked with the Qbox is likely to cause issues.
Have you tried removing the Alexa?
If you still have an issue
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
