12 Mar 2024 08:28 PM
My remote doesn't work the sky Q box sometimes the only way to repair it is to turn off at the main and back on again and it's ok, sometimes the channel your watching plays but the remote won't change of control any thing until you turn off the box and back on again, I have paired up the remote with the tv and I have changed the battery twice after testing them,any ideas??
12 Mar 2024 08:36 PM
Hi @davidduck22
First try a Reset Settings in the Q box hidden menu.
With the Q box back on
Try completly resetting your Bluetooth remote.
13 Mar 2024 07:57 AM
Thanks very much I give it a try and let you know later ,
14 Mar 2024 08:07 AM
Hi Again many thanks I done what you said and seems to be working fine now regards David
13 May 2024 08:53 PM
I tried the first reset today after receiving no satellite signal for a couple days. Now I can't even access any of the on demand services and recordings and downloads etc. literally nothing available anymore. When settings does first reset change that night affect this
