Discussion topic: Sky q box not working
Message posted on 20 Sep 2023 09:58 AM
My sky q box is super dark and anything inc people is dark red impossible to watch and my mini box will not connect
Message posted on 20 Sep 2023 10:20 AM
Re: Sky q box not working
Hi @Dave1275
Message posted on 20 Sep 2023 10:33 AM
Switch it all off and pull and replug the hdmi cable then turn it all back on
