Discussion topic: Sky q box not starting up
This message was authored by: jamestarrant30
My sky q box will not start up. Even when rebooting with plug
Re: Sky q box not starting up
hi @jamestarrant30
If your Q box is showing an amber LED on the front right hand side:-
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
If the box is completely dead:-
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Ordering a new Q box usually means a doorstep swap.
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of 😎 power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi -in din socket in the back of the Q box. See below.
Avatar for jamestarrant30
Ok thanks I'll try that tomorrow
