14 Feb 2024 08:24 PM
I got sky tv q box and it is not working. Each time i turn on sky box my tv goes blank
14 Feb 2024 08:30 PM
Hi @Afzal_Ahmed
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
14 Feb 2024 09:55 PM
Thank you. It is working perfectly fine now.
17 Feb 2024 05:01 PM
Hi. I'm encountering same issue again. Since i reset the resolution, it worked for 2 days but now again tv gone blank. I tried this code multiple times but it didn't help at this time. Please advise.
25 Feb 2024 03:20 PM
Hi. Could you kindly reply to my previous query?
