Discussion topic: Sky q box does not reset
This message was authored by: HalcyonDays
My Sky q box does not reset tried  turning off at main connection leaving 5 minutes the plugging back in again  It.Did start once the switched off again after 30 minutes No message apperas on the screen which remains blue cannot get any picture. TV does work on Anteena so it is not the TV
Re: Sky q box does not reset
Hi @HalcyonDays
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for HalcyonDays
Level 4 icon
Grren light is showing on front of Sky q box
Level 4 icon
SStartup for 5 minutes then Blue screen appears no picure with green light stillshowing omn Sky Q Box What should I do
