Discussion topic: Sky q box conection with 2nd mini box
Message posted on 22 Apr 2024 09:08 PM
Just need some help connecting 2nd mini box to q box ,it's saying technical issues when I go onto TV guide ,I'm not on sky broadband, when I go onto status of the minibox it has a tick on connection to sky q box and a tick on connection to Internet, I have done a software update on the minibox but that didn't help,the minibox is in my garage about 10 metres from the other minibox and 13metres from q box ,any ideas ?
Message posted on 22 Apr 2024 09:17 PM - last edited: 22 Apr 2024 09:20 PM
Re: Sky q box conection with 2nd mini box
Hi @Dale14
Assume it's connected by WiFi.
It it's currently connected to the main Q box try connecting it to the other mini.
To connect it carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WPS.
You will be asked to press the WPS button on the nearest Q device so use the other connected mini (not the mini you are trying to connect as the Network reset will start the mini WPS automatically).
Message posted on 22 Apr 2024 10:23 PM
Thanks for that i will try it tomorrow ,does the booster still work if you're not on sky broadband?
Message posted on 22 Apr 2024 11:04 PM
Booster still works even without Sky Broadband,
It will boost the sky q mesh
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 23 Apr 2024 12:02 PM
Hi @ThePope27 thanks for that I will get one sorted
Message posted on 23 Apr 2024 12:09 PM - last edited: 23 Apr 2024 12:22 PM
Hi @Dale14
First you would need to connect the booster to the main Q box using WPS on both devices.
Once it is connected then you need to carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Booster
You will be asked to press the WPS button on the booster (not the mini as the Network reset will start the mini WPS automatically).
If necessary you could connect the booster by WPS to the other mini (instead of the main box) if it gives you less distance and a better connection.
Message posted on 23 Apr 2024 09:38 PM
Hi @oldfella thank you for that much needed useful information
