Discussion topic: Sky problems with sky box software
This message was authored by: Sdboo
Hi everyone, I have a main Sky Q hub and 4 mini boxes. I understand I can only have 2 mini boxes on at a time but that isn't the problem, I'm fine with this set up. It seems every time I switch on a TV I get an error message saying 'cannot connect to sky mini box' therefore I have to go through the ridiculous scenario of unplugging everything and resetting the system. There is nowhere I can get any answers so the only thing I feel like doing is cancelling everything from sky, any ideas from anyone very welcome! X
Re: Sky problems with sky box software
@Sdboo
Try rebooting your hub then do a reboot of the main Sky Q box, then once that’s back up and running do the same with all the mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
The TV says it cannot connect to the Sky mini box??
