Discussion topic: Sky not working
This message was authored by: JasonClarke1234
Sky not working
The picture is pixelated
Re: Sky not working
@JasonClarke1234
With pixelation or any error message of “no satellite signal”, check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely either;
▫️a dish misalignment,
▫️a failing LNB (on the arm of the dish),
▫️water getting into the cabling,
▫️very heavy rain
so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
If you are connected to a communal dish you need to liaise directly with your building management company or landlord who will have their approved engineers to contact direct.
