Discussion topic: Sky not working
Message posted on 11 Nov 2024 08:50 PM
Sky not working
Unable to change channels on tv
Message posted on 11 Nov 2024 09:19 PM
Re: Sky not working
Hi @Millie9
Have you tried rebooting your Q box?
If you had to press the Standby button (Amber led) to bring the Q box on then,
Message posted on 10 Jan 2025 09:15 PM
Re: Sky not working
Sky not working
Message posted on 10 Jan 2025 09:48 PM
Re: Sky not working
@Benji6 wrote:
Sky not working
@Benji6 can you supply a bit more information such as what is not working, any error messages etc
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
