Discussion topic: Sky not working
Message posted on ‎16 Sep 2023 05:22 PM
Sky not working
Main box works the additional box in another room does not
Message posted on ‎16 Sep 2023 05:28 PM
Re: Sky not working
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Message posted on ‎16 Sep 2023 05:30 PM
Re: Sky not working
Tried all that thanks but it still isn't even responding to on/off switch!
Message posted on ‎16 Sep 2023 05:56 PM - last edited: ‎16 Sep 2023 05:58 PM
Re: Sky not working
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
