This discussion topic has been answered Discussion topic: Sky not connecting
Message posted on 10 Oct 2023 06:51 PM
Hello.
My sky will not connect to the internet
Message posted on 10 Oct 2023 06:54 PM
@Ellie19 wrote:
Hello.
Hi @Ellie19
Assume this is your main Q box
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 10 Oct 2023 06:53 PM
Re: Sky not connecting
It was working earlier
@Ellie19 wrote:
Hello.
Hi @Ellie19
Message posted on 10 Oct 2023 07:01 PM
I have tried all this
Message posted on 10 Oct 2023 07:02 PM
Message posted on 10 Oct 2023 07:03 PM
Sky
Message posted on 10 Oct 2023 07:05 PM
