Discussion topic: Sky multi room not working
Message posted on 09 Sep 2023 04:51 PM
Sky multi room box not working. Tried all the usual reboot options numerous times but it's still not working
Message posted on 09 Sep 2023 05:03 PM
Re: Sky multi room not working
Hi @Mick15
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
