Discussion topic: Sky multi room box
This message was authored by: Jo+t+Poole
Sky multi room box
My sky Q minibox has stopped working any ideas how to fix this please It starts up with the welcome bit then goes onto the blue screen where you have to press the house symbol after the screen goes blank but nothing happens and yes I have put new batteries in the remote, thankyou
Re: Sky multi room box
hi @Jo+t+Poole
May I suggest you try a reset of your remote:
Press & Hold the 7 & 9 until the remote's light (red LED above the SKY logo button) flashes 4 times
Then press 1 & 3 together to go through to re-pair with the box and your TV - make sure it has line of sight of the box as until it is paired it uses Infrared
https://www.sky.com/help/diagnostics/sky-q-remotes/setting-up-remote
Avatar for Jo+t+Poole
Thankyou that worked 🤗
