Discussion topic: Sky multi box will not reactivate
Message posted on 13 Feb 2024 10:42 AM
My multi room boxes will not connect to the main box. I checked the settings on the main box and selected reactivate in the settings. But nothing happens. This happens to any go also.
i have carried out a full reset of the main box but still the same. I need help please
Message posted on 13 Feb 2024 10:43 AM - last edited: 13 Feb 2024 10:48 AM
Re: Sky multi box will not reactivate
Reboot the mini as above. Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
