Discussion topic: Sky minis will not connect
Message posted on 04 Oct 2026 06:52 PM
Sky minis will not connect to sky q box despite software update and good WiFi they also keep disconnecting from WiFi despite good signal
Message posted on 04 Oct 2026 08:11 PM
Re: Sky minis will not connect
@Unhappy261 who is your broadband provider ?
If it's Sky what router do you have black or white ?
Have you tried rebooting your main Q box ie
then rebooting your mini ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Oct 2026 10:04 PM
Virgin broadband. We have tried everything on Sky Help pages. Main Q box has software updated but can't connect minis to WiFi or q box
Message posted on 05 Oct 2026 04:26 PM
@Unhappy261 right with a third party broadband provider your main Q box will ony connet to your Virgin router on the 2.4Ghz band on the router. Conneccting minis they will not connet diret to the router insted they do need to be onneted to your main box by way of WPS button.
are you getting any error messages when you try and connect the mini boxes
Have the mini boxes ever connected ?
Message posted on 05 Oct 2026 08:40 PM
Came home from work, didn't do a thing and they are all working, talking and connecting to each other 🫤
