Discussion topic: Sky minibox
Message posted on 03 Oct 2023 09:56 PM
Sky minibox
My Sky Q mini box has stopped playing TV channels. My main box is still fine.
It's connected to the internet - I can use apps like Netflix, and it's connecting to the main Sky Q box as it's showing the TV shows I've recorded. But it won't play them, or live TV. All it says is "Please check your subscription entitles you to view this channel on this box".
On the main Sky Q box, it's fine.
It's been doing this for a few days. I've tried rebooting, and reactiving, but no success.
I am still paying for it so know that I have the subscription
Message posted on 03 Oct 2023 09:58 PM
Re: Sky minibox
@Michelle350 when you say you have tried rebooting
Have you tried rebooting your main Q box ie
then
rebooting the mini box
Message posted on 04 Oct 2023 06:46 PM
Re: Sky minibox
Yes I have done this but it's still showing the same thing @Laing1
Message posted on 04 Oct 2023 06:53 PM
Re: Sky minibox
Hi @Michelle350
Try a Reset Settings in the main Q box Q box hidden menu.
If this doesn't solve your issue carry out a similar Reset Settings in the mini box hidden menu. (Same procedure as above)
