Discussion topic: Sky mini
This message was authored by: Kazza0970
Sky mini
Sky mini box is playing sound but has no picture. Not moving up or down tje channels either
Re: Sky mini
Hi @Kazza0970
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
