Discussion topic: Sky mini wont connect (20th time)
Message posted on 16 May 2024 10:20 PM
My sky mini won't connect to the router or sky q and even when it does the connection keeps dropping I have sky WiFi max so I will 100% be getting my money back I'd like a permanent fix for this also as this is not worth the money the fixes I have tried are reseting the router and the mini box and the main sky q box among all other fixes but it still isn't connecting to the Internet only to the sky q not happy will want compensation such lazy lazy staff
Message posted on 17 May 2024 04:09 PM
Re: Sky mini wont connect (20th time)
@Gamer01000 as far as I was aware the sky max router wasn't being supplied for customers that have Sky Q with mini boxes
Your mini boxes won't connect to the Sky max router as it won't be part of the mesh so you need to try and connect your mini boxes to your main box but as I said unless Sky have changed then the Max router isn't being supplied to customers with Sky Q mini boxes so this may be the problem
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 17 May 2024 04:12 PM
Recently changed to addresses with one Mini, I believe.
Message posted on 17 May 2024 04:32 PM - last edited: 17 May 2024 04:36 PM
@TimmyBGood I must have missed that, I knew it had been changed to Q main box thanks now i know
@Gamer01000 Ignore my post then
