Discussion topic: Sky mini won’t connect to internet.
Message posted on 21 May 2023 01:52 PM
Hi all, we have a Sky mini happily connected to our Sky q box. We have a second Sky mini box we can't connect to the internet to pair the device. We've completed factory resets, etc, etc. the symptoms are: 1. If we go through the reset process, we can't move on from the step 1 of 4 action (no button presses do any thing). 2. If we go to the internet settings via the home menu, you can't select the option to choose wi-fi from another provider. 3. If we go into the engineering section via the 0,0,1 code, both 2.4ghz and 5ghz options are switched off and won't switch on. 4. Also tried to connect via Ethernet, but an ip address wasn't found.
any advice?
Message posted on 22 May 2023 08:55 AM
Re: Sky mini won’t connect to internet.
Message posted on 24 May 2023 09:16 AM
Hi Size
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
