Discussion topic: Sky mini stuck on red led
Message posted on 07 Nov 2024 06:15 PM
Hi, my sky Q mini is stuck on a red LED. I can't get it to switch on. I've rebooted the main box and the sky mini and it still just stays on the red led. Can you help?
Message posted on 07 Nov 2024 06:17 PM
Re: Sky mini stuck on red led
Hi @Tracy109
Have you tried pressing the Standby button (Amber led) on the front of the minibox.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 07 Nov 2024 06:19 PM
Hello, it won't go into standby, I can't only get a red light. Thanks for replying
Message posted on 07 Nov 2024 07:08 PM
