Discussion topic: Sky mini showing technical fault
This message was authored by: Bobbird
I've changed box to two different TVs but small in screen showing technical fault fail
Re: Sky mini showing technical fault
@Bobbird Have you tried rebooting your main Q box ie
then
with the mini box try holding the reset button on the back in for 20 seconds
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: JamesFrampton
Tried that - didn't work
